Hey yall, I pieced together some upper & lower rear control arms for my ‘87 Wagon and posted about them over on the 2024 thread a few months back. I've put just over 500 miles on them, including driving through some pretty hectic rain storms these last few weeks. I got some interest from other members and was asked to start a thread on them… so here you go:
![](https://i.ibb.co/3hGZKyJ/IMG-8471.jpg)
![](https://i.ibb.co/N1YzX1C/IMG-8537.jpg)
![](https://i.ibb.co/6NqMd8g/IMG-8536.jpg)
![](https://i.ibb.co/wQ8NXKz/IMG-8495.jpg)
![](https://i.ibb.co/tZdDR7j/IMG-8716.jpg)
![](https://i.ibb.co/JcsSJyx/IMG-8553.jpg)
![](https://i.ibb.co/ZLPSjvQ/IMG-8550.jpg)
The parts I used:
For uppers:
X2 Allstar Performance Heavy Duty 3/4in Suspension Tube (7in length) part # ALL57448
X2 Allstar Clevis End Right Hand Threaded Part # ALL99320
X2 Chromemolly PTFE Lined 3/4-16 in. Left hand Threaded Rod Ends
X2 Allstar Performance High-Misalignment Rod End Bushings/Spacers part # ALL99321
For Lowers:
X2 Allstar Performance Heavy Duty 3/4in Suspension Tube (17in length) part # ALL57468
X2 Chromemolly PTFE Lined 3/4-16 in. Right hand Threaded Rod Ends
X4 Allstar Performance High-Misalignment Rod End Bushings/Spacers part # ALL99321
I used 1/2" hardware from my G-Body days which work well with the spacers (it's either grade 8.8 or 10.9 high strength nuts/bolts/washers).
I went for the strongest I could get within reason. DOM steel .160 thick tubes with plenty of thread engagement. 3/4” Chromoly PTFE/Telfon lined spherical rod ends (QA1 style). Ive used these heims before on a IROC-Z I sold a while ago… I put over 22K miles on them without noises or looseness developing here in North Texas. I personally wouldn't use standard heims as they were loud and vibrated in my experience on a 4th gen F-Body project.
In regards to the Box Panthers Converging 4 Link: I was having way too much axle movement both straight line and in corners. I have 250lb springs & bilsteins; however the rear would occasionally dance about. The main culprit was the old rubber bushings…
This is not my first rodeo with a converging 4 link rear suspension, as my ‘88 Monte had a very similar rear suspension as the Box Panthers. As a matter of fact the control arm dimensions are very similar. Technically the box panthers are prone to *less* bind as the arms are longer than G-Body’s (Box Panther: 20.5” Lowers & 12” Upper VS G-Body’s 19” Lowers VS 11” Upper). When I put heims/tublers in the Monte, it made a major difference in both straight line & cornering for the better. It felt much more smooth and predictable.
Anyway, I'm used to just buying pre fabricated control arms with heims ready to bolt on and go, preassembled with correct spacers and all. However there is not much aftermarket for the Box Panthers unfortunately. Weird considering the Boxes drive real nice and are cool looking IMO.
My original plan to fix my rear axle dancing around was to use Poly bushings on one end and rubber on the other pressed into the original panther arms. However no vender sells the correct replacement rubber bushings anymore unfortunately. So I started digging to see if G-Body bushings and arms would work on Box Panthers: they do not. The diameter of the bushings are different. The lengths are also different as mentioned above. However the width of the arms are almost identical.
The more I looked at my old UMI arms from my 3rd gen F-Body the more I realized how easy it would be to assemble them my self. And there you have it, i’ll keep yall updated on how many miles I put on them and how the heims perform... based off my previous experience I think they will last a while. I personally torqued everything down real good and used blue loctite on the jam-nuts just to be safe.
So far on the wagon it’s been the same experience as with my old Monte. It hooks up and handles much better.
-Kyle
The parts I used:
For uppers:
For Lowers:
-Kyle
