Originally posted by Arquemann
View Post
Get ready for an info dump Arquemann, as I have to correct some of my measurements:
There are two different size bushings in the factory stamped panther 4 link (both for the original rubber & ES urethane inserts): The 4 lower control arm bushings (axle/frame side), and the 2 upper control arm bushings (frame side) are all 6 the same size:
OE Rubber: 2.37” width, OD 2.08” small end & 2.11” big end
Urethane insert: (part #3345) 2.44” width (both bushing and inner sleeve), OD 1.98” small end & 2.01” big end
My original measurements that you quoted were taken with the bushing still installed into the rear lower control arm. I stupidly did not take into account that the control arm sleeve was also being measured!
I attached pics of original bushings and urethane inserts below.
Axle Housing bushings (both rubber & ES Urethane inserts) are a different size from the other 6 control arm bushings... Continued in post below.
