I’m finally able to get to installing a new master cylinder and I can’t get the fittings off the old one. I’ve tried wrenches, none fit and an adjustable wrench, which started to round the heads. Any good way of removing them so I can finally finish?
Master Cylinder Install
Are you using line wrenches or line style crow feet?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Sae not metric?
Sometimes I have had luck with vibrating the materials with hammer blows. On the master tight up against the fittings. Also use free all or the like.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I'd also had luck tapping the fitting with a /punch/hammer. Then with the line wrench, be quick and pull it hard and fast (think impact). Trying to go easy just rounds off the hex.1990 Country Squire - under restoration
Originally posted by 87GrandMarq View PostNot yet but since the threads are horizontal I don’t have too much faith in a penetrant working too well.What I Own: 1993 Mercury Grand Marquis GS
If you are replacing it heat the hell out of it.~David~
You said you are using line wrenches?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
