Steering column overhaul
Fun getting all that out. Flash backs to when I swapped in my t-5. I just pulled the column so it was out of the way of removing the pedal assembly.
this is one wagon that will survive.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Nice! Did you replace any of the rubber bushings? If so what did you use?-Phil
