1986 MGM Brake Lines
    Gents can you tell me the size of the brake line in my ride?
    In the spring I want to rip out all the lines (replaced one already that was rotted out) with Cunifer which should be easier than F-ing around with steel.
    Thanks for the info
    The hard lines are usually 3/16" but you might want to double check
      all the Panther lines I've ever seen are 3/16
        +1!
          Thanks guys, btw..............NYC wind chill is now 15 below zero............or as "they" say..............cold as a witches "tit"
            Oh, how much line should I purchase, Cunifer comes in rolls. No problem getting a bit more.
              And she's wearing a wet T-shirt!
                I usually buy NiCopp lines in 25' rolls
                Don't forget the fittings (or re-use yours)
                  The fittings at the prop valve are odd, so hopfully you can recycle them. The fittings at the other ends of the line are standard type fittings.
                    Are the fittings SAE or Metric? Fittings also 3/16th?
                      SAE double flare but the threads on the nut at the prop valve has larger threads than a standard 3/16 double flare fitting. All the rest are the usual size.
                      unless its just the hex part thats larger. At this point I don't remember for sure, other than something about those fittings is odd.
                        Nuts on the master cylinder are unique too! WagonMan
                        89 Colony Park
                        90 Colony Park
                        70 HEMI Daytona Convertible
