Originally posted by 96'vicp71
View Post
Posi Differential Info
yeah because when I bought my car I was told it had posi but only one wheel spins and I looked up the axle code and found out that its really a 3.27 open.
So would something like the 8.8 Ford Trac-Lok 28 spline on adtr.net work? http://www.adtr.net/shop.php?page=drivetrain
Originally posted by 96'vicp71 View Postyeah because when I bought my car I was told it had posi but only one wheel spins and I looked up the axle code and found out that its really a 3.27 open.
So would something like the 8.8 Ford Trac-Lok 28 spline on adtr.net work? http://www.adtr.net/shop.php?page=drivetrainhttp://secondhandracing.com/Home.aspx
Only a locker or spool rear will make the tires squeal and hop around corners. A traction-lock is not actually a locker rear, its technically a limited slip rear. It has clutches that allow the tires to move at different speeds.86 Lincoln Town Car (Galactica).
Well I talked to my dads mechanic today and he said it's really hard to put a trac lock in, and he said that I should just find a police interceptor that has posi and switch the whole rear end with mine.....Does that sound accurate or maybe he is thinking of something else?
Go back there, and tell him that it's really hard not to laugh at him....I did it in 2 hours, any shop in America can do it. There is nothing different about going to a posi unit than changing gears. The installation procedure is the same for a trac-loc, locker, spool, open, torsion, and what ever else differential is specified for a Ford 8.8 28 spline. He's an idiot.
Originally posted by lincolnmania View Postnow how in the hell are you supposed to get that truck s spring installed........i tried for over an hr before i gave up.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
I agree, fiddling with ancient control-arm bolts that use a big Torx head and DO NOT want to move no matter what, has got to be 10 times harder than swapping diff components that have at least been bathed in oil their whole life. And if you happen to get a complete carrier already assembled, it's even easier. Also a good chance to double-check your axle seals and bearings while the shafts are out - they're not that hard to replace, but make really bad noises when they go south.2012 Mazda5 Touring | Finally working on the LTD again!
Ford 9" rear, different animal entirely. It most likely would have been some form of clutch based limited slip though. Its the easiest and cheapest way, and for most street driving its perfectly fine.86 Lincoln Town Car (Galactica).
Ok, this is a noob question: what all parts would I need to get if I wanted to swap out my 3.42 open rear to a limited slip 4.10 from another Chevy truck? And what tools are needed to get the necessary parts from a junkyard truck?88 Town Car (wrecked, for sale)
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I'm assuming this is something like a Chevy 10-bolt rear end? There's a removable cover on the back of it, correct?
Anyway, assuming that's true, the parts you'd need to get from the boneyard would be the carrier and the ring and pinion set. Tools needed shouldn't be much more than just basic hand tools, though trying to get the pinion nut loose without an impact would undoubtedly be rather interesting. You'd probably be better off trying to buy the stuff already removed (eBay, perhaps).
Then you'd want to get a ring and pinion installation kit, which should come with outer axle bearings, carrier bearings, pinion bearings, carrier shims, pinion shims, crush sleeve, axle seals, and a pinion nut.
I may be forgetting a detail or two, but that's the majority of it.
