Would an 89 Crown Vic Police sedan have the metal control arm bushings? I have searched, but can’t seem to find the thread that talked about them. I know I saw a pic that someone had posted, but I can’t find that either. If I wanted to do the swap what would I need? Just the upper control arm or will I need more? My 89 factory service manual shows a picture but it’s hard to tell what is different or what would be needed for the swap. These look like a pain to pull, but if they are in good shape I’d like to get them before the car is crushed. Thanks!
Police sedan front control arm?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yes, PI cars have the control arms with metal bushings, but you're better off getting polyurethane bushings for your stock civi arms. The metal bushings in the PI cars wear out and you can't get them anymore.
I think there's a sticky in this forum about how to do the poly bushing swap.
Originally posted by Nathan in MNYes, PI cars have the control arms with metal bushings, but you're better off getting polyurethane bushings for your stock civi arms. The metal bushings in the PI cars wear out and you can't get them anymore.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Okay, I stand corrected. I know Stu found a set for his car, but as far as I know they were NOS parts. I guess the real question would be whether the benefits are worth the hassle of finding them in the first place. The ones on the car he's talking about are probably worn out already. Just my humble opinion.
The upper and lowers are both different. You don't have to swap both. The metal uppers are very difficult to find, and you will probably be stuck with used ones. I would imagine they aren't difficult to machine yourself if you have the tools. It would be easier and less expensive to go polyurethane on the stockers, and the difference between the two would be negligible.Builder/Owner of Badass Panther Wagons
