what can i do for suspensoin upgrades? do they sell poly bushings for the cvs? do upper and lower control arms from a mustang work? also what suspension parts are interchangable from cv to cv years? thanks
front and rear suspension
*sigh*
http://www.grandmarq.net/vb/showthread.php?t=4073
http://www.grandmarq.net/vb/showthread.php?t=13987
rear bushings should be the same as 92-97 application.
PLEASE PLEASE PLEASE try doing a search and do some reading.Builder/Owner of Badass Panther Wagons
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
PI bushings are metal. You'll have to get civilian control arms in order to use poly bushings.
On early models they are metal, yes. Those bushings are also made from Unobtanium and no longer avail from Ford. Later models used a different upper control arm. Police models have two large bushings, while civvie models got one large and one small. Thats really about the only difference.86 Lincoln Town Car (Galactica).
yes. Mostly from lack of lubrication over the years. There are grease fittings in the upper control arm shafts but half the time they're ignored so the bushings wear out. If you use those, you're pretty much stuck with stock parts though. No brake upgrade since you cant replace the upper arm.86 Lincoln Town Car (Galactica).
You *can* swap the bars, but its not necessary. There may be clearance problems using the newer style bars. Old ones work perfectly with no modifications.
RE: poly parts, yes, you can use them on the 98-02 front suspension, or I think you can get a kit for the stock suspension parts too but you keep the wimpy brakes with that.86 Lincoln Town Car (Galactica).
