flipping through Speedway Motors catalog yesterday i decided to go measure the upper control arms on the 85.
the 85 uses a 7 3/4" bolt spacing, 8.25" legnth and an offset design (offset by 1 1/4".
A 1970-1981 Camaro uses upper control arms that have a 73/4" bolt spacing and come in lengths between 8 and 9 1/2" in 1/4" increments. But it is a non-offset design.
they both use a four bolt upper ball joint
the Camaro arms are almost a perfect match.
Today i was looking through a catalog from www.a1racing.com/
They have control arms in the proper spacing, length, and offset, with 4-bolt ball joints in either aluminum or steel. They are about $50 each.
Their site does not list the size, but ill look it up in the catalog tomorrow, even in steel these arms would easilly cut about 10#s off each side of the front suspension, im going to look into the aluminum arms for maximum weight savings.
This is what they look like. compare that to the heavy stamped control arms on the box panthers.
The only thing im concerned with is how the panther control arms are bent up at the ends, im not sure if the chevy arms are or not.
