Front wheel bearing torque
    Im just wondering what i would torque my front wheel bearings to on my 84 since im going to change them tomorow night maybie,
    tighten them until you can feel drag on the rotor, then go a little bit tighter.
      ok so that will be fine then,,, i wasent sure if i would mess them up if i dident torque them . thanks
        They dont get very much torque at all, it would be measured in inch-pounds if you were.
          yea - I like to install the wheel and wiggle it to feel for play... just tighten it untill you feel the play just barely stop then a scooch more.
            The manual suggests that you first torque the bearings (while spinning the wheel) to 17-25 ft./lbs. (23-34 N m) to seat the bearings, then loosen it back up 1/2 turn, and tighten it to 10-12 in. lbs. (1.1-1.7 N m). Basically, just tighten it enough to get rid of the play.
            Whatever you do, after you're finished, drive it a little bit and then lift the car up again and recheck the wheels for play. Sometimes they can loosen up a bit the first time.
            Wow. 400th post and it's actually legit. Whoda thunk it?
              It's only PRELOAD!!
              1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
              FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
                ditto
                  189-250 ft*lbs...
                  For the newer sealed bearings
