backspaceing
    backspaceing
    will wheels with 4.50" backspacing work with out spacers on a 89 cv???
    also i would like to see pics of peoples cars with aftermarket wheels on them ... thanks
    Need more specs...Wheel width is pretty important to know.
    For pics look in the reader ride section of the site.
      17x8 , +0mm offset, 4.50 backspacing
      sorry, i guess that WOULD be important info lol
        I think that'll work....If I am correct, I am running 17x8's with 5" and they have plenty of room to go out to the fender.
          My 17x8 bullitts are around 4.5" of backspace with the spacers, they fit great.
            will these wheels fit with out spacers?
            15 in. x 8 in.
            5 x 4.5 in. Bolt Circle
            4 in. Backspace
              what is the backspacing of stock wheels?
              do any of you have slightly wider 15" tires that are the same diameter as stock tires?
                They should. You want to find a wheel with zero offset, so the backspace is half of the over all width.
                -Matt
                  Yes and Yes to both wheels you listed.
                  -My Homepage, Panther info & FAQs-
                  My Mint 96' Mercury Grand Marquis LSE -
                  Modifications
                  Click My Merc for more Pics!
                    Stock is 215/70-15, which is a 27" diameter tire. Wider than that and perfect for the 8" rims will be the 255/60-15 tire, it's also 27" in diameter so it'll not mess up yer speedo calibration.
                      Im running 325/50 R15s (28" tall with 13" sidewall to sidewall) on a 15 x 10 wheel with 4" of backspace, with 5" of backspace you could get away with rolling the fender lip, with the 4" like i have i have to keep the rear up high to keep the tire out of the fender.
