without dumping tranny fluid? I might install my aluminum driveshaft tomorrow in my C4, but i dont want to pull the shaft and drop a bunch of fluid because i only have 2 qts of Type F
can i pull my driveshaft
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
If you put just the back end up in the air it shouldn't leak much at all.86 Lincoln Town Car (Galactica).
yes jack it by the ass end
alright. i guess ill have to wait to do it then. Right now all our jackstands are occupied holding up my brothers car for the motor R/Rhttp://secondhandracing.com/Home.aspx
clean a out a drip pan! (just in case) even if some leaks it wont be much.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by phayzer5I got 4 jackstands and my racing jack, but they're 2 hrs awayhttp://secondhandracing.com/Home.aspx
Originally posted by LtMercDaddyyou got drive up ramps? if they clear ur rear fenders, back up the ramps should get the tranny enough pitch to not spooge.... plus all the bolts are on the rear....
We do have a set, but they wont clear 13" wide tires. They dont even like 11" wide tireshttp://secondhandracing.com/Home.aspx
well if driving up them is the problem, just jack the diff and lower the ass centered atop each pocket of the ramp, aslong as its centered and level and ur not exceeding the ramp weight capacity u should be fine... its not like ur gonna be up there forever......1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
Originally posted by LtMercDaddywell if driving up them is the problem, just jack the diff and lower the ass centered atop each pocket of the ramp, aslong as its centered and level and ur not exceeding the ramp weight capacity u should be fine... its not like ur gonna be up there forever......
With the 11" tires the tires are supported by the sidewalls, my 325's would be sitting on the edges of it. Not a big deal anyway, the jackstands should be free pretty soon.http://secondhandracing.com/Home.aspx
