I would absolutely go C4. The AOD is quite frail...if you're building a track toy then OD should be a non issue. C4's are super cheap to build too. I've seen too many AOD transmissions fail in stock or near stock 5.0's. Keep in mind, transmission torque capacities are also calculated against vehicle weight. The heavier the vehicle the lower the torque capacity.
Good luck!
-Don
Good luck!
-Don
