You can make a lopo run pretty good. It will never be "quick", but low 16's/ high 15's are obtainable. I don't think people give them enough credit.
Upper/lower explorer intake swap sensors not matching up, need help!
Originally posted by pantera77 View PostYou can make a lopo run pretty good. It will never be "quick", but low 16's/ high 15's are obtainable. I don't think people give them enough credit.
Then I found this guy's thread: http://www.grandmarq.net/vb/showthre...toria-Slicktop claiming 17s with a stock 88, looks like my estimate actually wasn't off according to what this guy says in his thread.Vic
Originally posted by VicCrownVic View PostMy cousin's husband's brother was running 14s in a little VW Golf, I told him my car could probably run 17/18 (I was only guessing, 3-4 seconds would actually put it quite some distance behind something running a 14), he looked at it and said "yeah right, probably like 25". Since I wasn't actually knowledgeable on the subject there was no debate.
Then I found this guy's thread: http://www.grandmarq.net/vb/showthre...toria-Slicktop claiming 17s with a stock 88, looks like my estimate actually wasn't off according to what this guy says in his thread.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by pantera77 View PostNo, your pretty much dead on. I've watched multiple bone stock SEFI cars run high 17's all day. Low 17's - high 18's is actually spot on.Vic
Originally posted by pantera77 View PostNo, your pretty much dead on. I've watched multiple bone stock SEFI cars run high 17's all day. Low 17's - high 18's is actually spot on.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by packman View PostBattlewagon ran good last April. Though it's not exactly a lopo. Must surprise people every once in a while though.
Originally posted by 88grandmarq View Postmy siver 88 MGM, ran consistent 17.2-17.1 qtr mile times with dual exhaust, 2.73 gear and 225/70/15 tires2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Alright.. well it looks like after the work something didn't match up right on the lower end and I'm 90% sure its the lower intake leaking right now, and not the rear main seal.. it just looks that way because the lower is leaking all over the place. What gives it away is the oil on the plugs & wires around the trans. So I guess I'm going to go back in. I'm thinking of replacing the injectors since the ones in my car right now were painted (I'm assuming it was a 'injector service' my grandparents got) and the IAC which looked pretty bad. Any suggestions are welcomed. I think this time I'm going to use sealer instead of the rubber gaskets.1991 Grand Marquis LS blog- Mayhem; two 12" Kenwood 800w subs, True dual catback, BBK shorties, cherrybombs, steel top, L/H hella lights, 18" AR Torq thrust, Trans cooler, class 3 hitch kit, more on the way...
Use the rubber gaskets. They don't leak if installed properly. Should go on dry with a dab of sealer in the corners only. This is assuming its the good kind that are molded to fit over the end walls. If its just the flat strip, go for better gaskets. The FelPro Permadry gaskets live up to their name, but they are not the cheapest thing you can get.86 Lincoln Town Car (Galactica).
The gaskets I use were like blue rubber that did have a lip that went over. Perhaps I installed it wrong though, it was quite a pain getting the lower back in. Is there a certain way you are supposed to slide it back in?1991 Grand Marquis LS blog- Mayhem; two 12" Kenwood 800w subs, True dual catback, BBK shorties, cherrybombs, steel top, L/H hella lights, 18" AR Torq thrust, Trans cooler, class 3 hitch kit, more on the way...
As long as you made proper clearance room for it, you should be able to just put it on straight down. Much easier with the distributor pulled, and zip tie the throttle bracket away. You can also use long cut bolts as guide pins when setting it down.
I use the gaskets you're talking about. I use sealant on the side non rubber gaskets and sealant in the 4 corners. Then torque it down following the bolt pattern. Then heat it up and torque it to the warmed specs.1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
What he said. Use guide bolts and just set it straight down. It keeps the side gaskets in place too doing it that way.86 Lincoln Town Car (Galactica).
Originally posted by Stealthlead View PostThe gaskets I use were like blue rubber that did have a lip that went over. Perhaps I installed it wrong though, it was quite a pain getting the lower back in. Is there a certain way you are supposed to slide it back in?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by Stealthlead View PostCan someone explain to me what you mean by guide bolts?
You can take an old set of intake bolts, I think I used 4 of those long upper bolts not sure. Anyway you just get 4 same thread same size bolts as the lower intake bolts just get them longer so they will stick up through the intake so you can take them out.
You cut the heads of the bolts off and use them to guide the intake Ito place. Also holds the gaskets still on the heads. Once the intake is down, just thread in some actual intake bolts and take the guide bolts out. Don't put them in tightly gotta be able to remove them by your fingers since they have no heads.
Ideally something like this:
I think you can purchase actual pins, but cut bolts work just the same1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
