My friend converted an 83 carb marquis to run on e85 and he says he loves how it runs and performs can i convert a 85 with cfi to run on e85 is it worth it?
dumb e85 question
You will need a higher compression engine. I think the cfi ecu cant compensate for increased airflow. Your gas milage will be twice as bad.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
you'd probably have to convert to carb first. If the CFI is working... it's not worth it. You'll get better mileage out of the CFI.
Originally posted by 90ltd View PostYou will need a higher compression engine. I think the cfi ecu cant compensate for increased airflow. Your gas milage will be twice as bad.Scars are tatoos of the fearless
e85 is a fucking scam. You get 15% worse gas mileage. Getting 300 miles per tank on the freeway? BAM, fuck you, you only get 255 miles per tank on e85. With the price difference you will pay more per mile traveled on e85 than you will e10-15 whatever bullshit. Even with the government subsidies, it's still more expensive to run e85 in the real world.
You even lose 10% gas mileage with the e10 bullshit all the states have switched to. If you're getting 400 miles per tank on the freeway, you could actually get 440 miles on pure gas, if you can find a station that sells it.
See articles on TTAC by Jack Baruth using e85 in his Town Car: http://www.thetruthaboutcars.com/201...chance-on-e85/ & Results http://www.thetruthaboutcars.com/201...iles-with-e85/Last edited by sxcpotatoes; 11-14-2012, 12:50 PM.
IMO, the only good thing about E85 (aside from the environmental stuff when made the way brazilians make it, NOT from corn) is the detonation resistance. This, as mentioned, requires a compression increase or boost to really take advantage of. It's higher octane than 94 octane gas and I know from my 351W vic that these cars, stock, don't benefit from timing beyond what 91 octane can support. If you want to run 10.5+ compression ratio or significant boost, that's when E85 starts being a nice choice.
Of course, supply is still an issue. here in Ontario, Canuckistan I don't recall EVER seeing E85 at the pump. 87 octane is E10 (10% ethanol), 89 is 5 or 10% and then 90+ octane is all gasoline. I don't have personal experience but I gather there are US states like this too, so if you build a car that needs E85 in a state where it's common, be aware you'll have to detune the car (probably pull major timing or boost) if you travel to some other places on the continent.
I know the debate rages gas mileage cost and what not the only reason i like it is the ignition boost the cooling effect of the alchol and if you run it consistantly it burns cleaner they have done studies where the ran cars 100k then cut open the cat the e85 looked new gas not so much and if you didnt have to buy cats or o2 sensors or anything that gets gumed up i think thhe difference in the e85 price is worth it
What about fuel system corrosion???
Originally posted by turbo2256b View PostIncreased fuel flow not air. Other issues requires different cats, different oil, higher compression, upgrade fuel lines to SS
This is what I have learned and more from goverment and state studys. I keep an eye on this stuff from time to time look up info again periodicly. Same studys also break down E 10, E15 and E85 fuels and what happens to autos also small engines.Scars are tatoos of the fearless
