Going from FI to carb just got easier
    Finding these fittings makes plumbing up a carb a no-brainer. No more cutting and hacking factory lines to install a carb. With Aeromotive fitting 15101 and Jegs fitting 103116 (or Aeromotive 15102 which has a pressure gauge port built in) it is easy to plumb in a return style regulator.
    15101 Aeromotive 3/8" $32 (from Jegs)
    15102 Aeromotive 1/2" $70 (from Jegs)
    103116 Jegs 1/2" $13
    103111 Jegs 3/8" $12
    103110 Jegs 1/2" $12
    UPR Option Part number 4011 $47.99
    Nice! Very nice! After re-routing the fuel system in Putter Project, I am not so afraid doing this to the CV; although I am keeping the EFI. A friend of mine is thinking of converting from cfi to carb in his '84 MGM. If we end up doing this, this will be of great help.
      Cool - Part numbers, specs AND photos. It doesn't get any better - GREAT job by "Merc"!!
        CFI cars do not use the quick connects. These aren't useful for such a thing.
          True but there are other fuel injection fittings available and CFI is easy enough to deal with... There are alot less CFI cars out there.
            I know. It was specifically directed towards this post, mostly as a heads up. I'm not looking to install a carb on anything, nor deal with a CFI car anytime soon.
              I will be using these for when I plumb the lines to my Navigator motor. Thanks!
