Mustang EFI wiring harness
    Is there any way to use the wiring harness off of a foxbody to fit to a panther? I don't know what exactly is contained in the harnesses. Thanks.
    Blane
    85' Crown Vic 2dr. Small tire stock block grudge car.
    09’ CTS-V family car making over 700whp with ease.
    79’ f350 427 ls7 swapped with th400. Prerunner setup
    64’ c30 dually. Slammed and turbo 5.3 with 4l80e
    Of course, it's just a PITA.... Why not get a panther harness?
      So much easier to find a mustang than panther where I am. Thank you, I wasn't sure.
      Blane
        you can find 5.0 Mustangs easier than 5.0 Panthers? huh, around here you *never* find a V8 Mustang in the yard unless its completely gutted.
        Anyway, yes it can be made to fit, no it won't be easy. The panther harness will physically lay in place neatly, and its grossly easier to wire it up if the parts fit where they need to be. Fox cars have the ECM and battery on opposite sides vs a panther, and the upper intake also faces the wrong way. I guess maybe you could flip the whole harness upside-down, but it still won't quite fit right without some surgery.
          Agreed. Although I did find one 86 5.0 Mustang with only the upper intake missing at EZ pull... If you have access to 5.0 Mustangs at your yard, can you get any Mass Air Flow, Automatic Transmission computers?
