I saw some blue top injectors @ the yard, they are the tall thin ones like an Explorer. I don't recall if they were on the Expedition or the Mark VIII.<br><br>Does anyone know if they are 24 pounders? will they work w/our ecms & rails?<br><br>Thanks
"blue" injectors
"blue" injectors
Tags: None
Originally posted by mitymerc View PostI saw some blue top injectors @ the yard, they are the tall thin ones like an Explorer. I don't recall if they were on the Expedition or the Mark VIII.<br><br>Does anyone know if they are 24 pounders? will they work w/our ecms & rails?<br><br>Thanks
The blues have different specs. It would be like replacing the stock inlectors with 19# without changing to a HO ecm. With a tuner such as a Teeecer it could be accomplished. A 93 Cobra ECM could be used with them but it would also mean converting to MAS air meter from the same and some wiring changes. I did run such a set up for a while in my GM. Some of the "pencil" style injectors are a direct fit in our engines not shure when they became diferent. I used some FMS pencile ones.Last edited by turbo2256b; 09-07-2011, 09:27 AM.Scars are tatoos of the fearless
Originally posted by turbo2256b View PostThe blues have different specs. It would be like replacing the stock inlectors with 19# without changing to a HO ecm. With a tuner such as a Teeecer it could be accomplished. A 93 Cobra ECM could be used with them but it would also mean converting to MAS air meter from the same and some wiring changes. I did run such a set up for a while in my GM. Some of the "pencil" style injectors are a direct fit in our engines not shure when they became diferent. I used some FMS pencile ones.
Originally posted by mitymerc View PostI have a set of pencil type explorer inj's on the '87, if I acquire the 24's they will be used w\aftermarket maf calib'd to 24 lb like on my Capri.I'll double check the cn's & if necessary, grab the inj harness for the plugs.ThanksScars are tatoos of the fearless
I think the v8 continentals had plain old 24lbers with the old school connector. That's what I run in mine.
Might be able to just change the plug on the other wiring and not cut anything to make the newer ones work.
Unless you are running a lot of mods 24's aren't needed though. And the different style injectors flow differently...So, depending on what the MAF is offset to it won't run that great... A tuner is a better way that a "calibrated MAF"Builder/Owner of Badass Panther Wagons
I've been running a pro M 77 & 24's on the Capri for quite a few years w/no prob....it's best pass was 11.90.
The CV CS has the GT40X heads & Exp intake from that combo, it is currently using a stock '88 5.0 LX cam & 19's SD though.
I don't know what the tweecr is going for these days but years ago it seemed to be a little much for what I am trying to do here....(& fuggetabout dyno time & custom tunes LOL)
