Is the mustang weatherstripping the best option for the doors on a 2 door? If anyone has used them are they good and are they long enough
Mustang weatherstripping
Daniel Carpenter kits say the length of their pieces is about 155 inches.
I bought a Fairchild KF3005 kit for an '87 Foxbody. I used them on my FOUR door front doors and had over a foot extra. I don't know if that's enough for a two door - door.
The Fairchild kit is good quality, but it's quite thick and I still require some doorslamming after 2 years.
It's just right angle pinch weld weatherstripping, it should be available in bulk too.1985 Mercury Grand Marquis LS, "Maisa"
2005 Volvo V70 Bi-Fuel
- Likes 1
Originally posted by Arquemann View PostDaniel Carpenter kits say the length of their pieces is about 155 inches.
Originally posted by Swayze View Post
Is the Fairchild bulb as wide as the factory ones? I got a mustang set from LMR and the door barely catches the seal
Just a sanity check, do your doors sit flush? Are your window frames okay, do they sit nicely in relation to the A- and B-pillars? How about your striker bushings?1985 Mercury Grand Marquis LS, "Maisa"
You can get the bushings at any parts store in the HELP section. if you have the older style you have to get the whole unit (dorman makes them, and they make it so the bushings are replaceable). i had a problem with the older style and their bushings, they were too thick, so i actually used some 1/2" CPVC pipe and it was perfect-Phil
Originally posted by mcb82gt View Post
Threadjack.... are they supposed to have striker bushings? My sons car has none on all 4 doors. Are they a replaceable part or buy the whole striker? thanks!
RA: (also pn. SK38448)
Auto Parts for Your Vehicle at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
LMR:
https://lmr.com/item/LRS-22008B/83-9...r-Reproduction
LMR sells just the bushings now too:
https://lmr.com/item/LRS-BP241PR/197...riker-Bushings
