87 302 Sefi shuts off after it is placed into park. 9/10 It will just shut off without warning after a drive, example; today I drove into a parking lot pulled forward then put it into reverse and backed up, as soon as I put it into park it shut off. Any ideas of what it could be?this used to be a rare occurrence but it seems to be happening more often now.
87 Grand marquis 5.0 Sefi
I'd be inclined to look at the ignition switch if it just dies. It lives in your steering column. https://www.rockauto.com/en/catalog/...er+switch,4700
If it's more of a slow stall, maybe we can chase another problem.1990 Country Squire - under restoration
+1 I would suspect ignition switch that coming apart since park is usually the most jarring to the column.
All i did was adjust the tilt to a "better" position went to start the car and it stalled. Started again, stalled. Then, I opened the door (listen for fuel pump) I turned the key on didnt hear the pump like I normally would. Then waited a few seconds tried again and it started and stayed running. Starter ignition
Few months ago, Anyways, what brand switch did you guys get and how well is it holding up?
I think I have either the Standard or Wells/Airtex version in my 93. The 88 I used to have got the same. Haven't had an issue with them myself. The design itself is prone to failure due to separation. I've not seen one yet that doesn't have the same fatigue points, but the fact that they still last 20-30 years, I don't think it's a major issue.
yea its still doing it, New switch exact same issue. One thing I can say for sure is it only happens after driving for more than a few minutes. Only happens once the car is placed into park, the sudden change in the rpm seems to cause it to stall. I could restart the car right away glide the shifter through all the gears then back into park and it wont stall, any ideas?
ECT and IAT(ACT) might be worth checking. Often those will cause a stall when coming to a stop if they are out of spec, but I suppose a change in engine load by putting the car in park could also be a condition where one of those two temp sensors being wrong could cause stalling.
ECT: https://grandmarq.net/oldfuelinjection/page28.html
ACT: https://grandmarq.net/oldfuelinjection/page29.htmlVic
A sticky idle control motor can also do this. if its trying to back the RPM down when it comes out of gear and overshoots it might just cut the air entirely and cause a stall. Most of the time you can simply unbolt it and give it a flush to dissolve out the gunk inside. Its the tubular thing bolted on the back side of the throttle body. 2 bolts and a plug.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostA sticky idle control motor can also do this. if its trying to back the RPM down when it comes out of gear and overshoots it might just cut the air entirely and cause a stall. Most of the time you can simply unbolt it and give it a flush to dissolve out the gunk inside. Its the tubular thing bolted on the back side of the throttle body. 2 bolts and a plug.What I Own: 1993 Mercury Grand Marquis GS
And maybe give it a shot of silicon lube where the plunger goes into the motor/solenoid.
Originally posted by friskyfrankie View Post
If one is going to spray it, make sure it is facing down so as not to get cleaner into the electrical parts. At this point, I'd replace it since it is somewhat difficult to access, but that's just me!
I've seen goofy things with non-OE parts on these, so I've kind of gotten to the point where I'll try and fix an original before replacing it just because I've had better luck with that.86 Lincoln Town Car (Galactica).
