Bottom end work
    Bottom end work
    How much should it cost me to do this....
    bore out cylinders .030" over
    put in new pistons and rings(I provide)
    put in new bearings
    my mechanic told me it should cost 400 bucks, is that about right?
    I don't really know. I've never done that before. But I don't think i'd pay that much.
      I called up the local machine shop and they said 800 bucks! WTF?
      they must have thought that I needed a new crankshaft and connecting rods...those alone are about 400 bucks.
        oil pan 99.21$
        block prep 325$
        hazardus waste reduction 5$
        rings 94$
        grind pass 010" (cam) 106$
        v8 / 16 valve / push rod re 414$
        oil pump 46.81$
        inter shaft 8.98$
        gasket kit 155.43$
        water pump 72.30$
        cast pistons 32.61 * 8 260.35$
        wtf i cant find my recipt for my bearings.....
          im prettu sure the bearings were under 50$ tho
          depends on what they want to charge you for assembly.
            Bore 30 over, R&R rods, resize rods big end, ARP rod bolts, hone cylinders, pollish crank, rod & crank bearings, pistons, rings, ballance, new head bolts, oil pump. Runs around 1200$ or less. There is the hillbilly rebuild but depends on your cylinder wall condition.
            I also have a hillbilly rebuilt long block in one of my Vics that I would let you have for 500 as a short block.
              If you can deal with hyperuetetics pistons then the 5.0 shortblocks can be had brand new from ford for around 1200..
