Block identification
    I found the block number on my engine, was wondering what they mean:
    E5AE
    03B
    E = 8 (decade)
    5 = 5 (year)
    So it's a 1985 block... not too often have I seen year models with blocks cast the same year.
      Dumb question here...I was ripping into my 302 roller block e7 casting but the rods were C8's...why would 1968 rods be in my 88 motor? Did ford just use the same rods through all the years?
        Where is the block number?
          Behind the starter.
            Cool thanks man :->
              1985 motors have a flat tappet cam, but they have the bosses in the lifter galley that can be drilled for the roller lifter retainer. Probably means its the original one in the car.
              No idea about the rods but I wouldn't be highly surprised if the original connecting rod design from 1968 (first year for the 302 I believe) is still in use. I didn't pay attention to the castings on my rods.
                Darknight-If you lay down under the car, look between the starter and the block, it will be on the lip where the bellhousing for the trans mounts up
                  Yes...... not an uncommon thing. Why reinvent the wheel? I believe that other rods were also used in that time frame though.
