Not enough CFM?
    Not enough CFM?
    Out of curiousity I wanted to find out what the CFM of my 2150 2bbl is, and it's pretty low. 287 CFM. Can having it too low cause driveability problems? I found out I can get it worked on so it will flow close to 400 if I wanted to. What do you all think?
    Swap to a better 2 barrel that flows 400cfm, or a 4 barrel.
    Nick
    88 Colony Park LS
      3 2 barrels works for me. Or a Holley 2 bbl throttle body the cheep one with out the feed back just the in cocpit adj unit.
        See if Scott has my old big block motorcraft one still...that prolly flows better than that. But it shouldn't cause any issues. I ran a 2bbl 82 mustang GT motor with no problems at all.
          Driveability issues would be caused by jetting or dirty carb parts. Typically the flow number is going to be most important at WOT when you need the highest flow. With a stock engine, you're not pushing that flow number past the carb you have in there.
          ~Adam
          '85 2-Door Crown Victoria
          302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
          '04 Crown Victoria LX Sport, '02 Jeep Liberty
          '83 Suzuki GS 1100E Motorcycle[/color]
            :stupid:
            Make sure the jetting is right, and your fuel pressure is OK. How do the plugs look? Usually thats a good indicator of the fuel mix. Overly white could be either under-jetted or the fuel pump isn't feeding enough.
              You callin' me stoopid?
                Tell us more about that fuckin truck!
