I took off the plastic hose/ducting leading to the air cleaner assem?
what would happen if
nothing.... your air charge may be warmer, so you might have a very slight change in fuel efeicciency....Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
What will happen is if your power steering pump blows some fluid it will land exactly in the air-cleaner box, get sucked in, and fuck up the filter. I say either keep it as is, or remove the whole airbox mess and run a straight pipe like mine, or mount the filter directly to the rubber elbow like the Superlinc.
I think he has a 351 in there... no need to worry about power steering fluidPete ::::>>> resident LED addict and CFI defector LED bulb replacements
i would make a dual snorkel setup like the 80's carbed and cfi ho mustang gt's had......the used oem ones are way too pricey, you can make your own with a snorkel from an extra air cleaner base, and some flexible hose, maybe dryer hose?
