Name that part! :->
    Name that part! :->
    Ok lets see who can name this part :-> Ive been trying to fig out what it is due to i have two of them. ive got an idea though of what it might be.
    Here it is
    MAP sensor.
    Save a seal, club a liberal.
      Thats what i thought it was ( Ha Ha ) Wth is a MAP sensor anyways? And how can i tell if i got the new one on or the old one on?
        the MAP "senses" the vacuum the engine is pulling, from which the computer can determine how much load there is on the engine and adjust the A/F mixture accordingly (it corelates the MAP reading with the one from the TPS). Whether you have a new or an old sensor I have no idea how to tell - my Townie I'm running one from an '88 LSC, and I only know it cause I put it in there, visually they are exactly the same.
          Cool, thanks man. Tune in tomarow folks to see another of what i call. wth part is that? its not in my book???? ) Any how thanks guys.
            Are you sure you actually need one? They don't fail very often.
              Well, i dought i do ha ha, i just had one in my trunk and didnt know what it was, and was woundering why it was back there.
                Probably someone started replacing stuff trying to fix a problem in the past.
                  yeah, I tried out like 4 of the 8 MAP sensors I pulled out of the junkyard, didnt seem to make a damn bit of difference how mine ran. Not even with a new one...
                    Allrighty, heres are next part in wounder... WTF is that for or what is it.
                    And here it is.
                    Front side
                    Back side
                    And this is a part that is in the Trunk.
                      thats your fuel pump shutoff switch - you need that.
                      if the car is in an accident, the shock will make that little white pin pop up. Push it back down to re-set it.
                        Kick Ass! i got all kinds of parts today im woundering about so heres another,
                        Ok if you look down here
                        You will find this on the exsaust manifold
                        Thats as close as i could get without it being utter blurey.
                          Hi Dark Knight
                          Exhaust Oxygen sensor
                          Regards
                          Dereck
                          President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
                            Make them harder!
                            -Matt
                              Cool o2 Sensor let me go take another pic of another part.
                              One soon to come
