So i was thinking today and u guys are right
    I think i ll just put a 351 in but i was thinking of getting a fuel injected 351 (better gas milage) but with that plop in or do i need to weld me some new brakets and stuff like that i was thinking of getting it from a truck or a van so tell how would i go about doin this
    Lefty Loosey Righty Tighty....
    What is your question?
    Use the same motor mounts as your 302, use a dbl hump pan, use accy brackets from a CV.
      An EFI 351 won't fit without hood modifications.
        Free post.
          an efi 351w is gonna be big bucks and then youre gonna have hood clearance issues.....i dont think it's possible to use the truck intake, it's way tall....i'll say it again, a 302 ho out of a donor mustang or mark 7 (best bet less beat on and mustang guys always forget the 88-92 lsc has a ho)
            who needs a hood? Smooth out your firewall, clean up your motor and paint it all nice, clean and loom all wires and run it without a hood. Just dont drive it in the rain.
            A 302 HO would be a great swap, and shouldnt be too expensive. You get forged pistons too if you want to spray some nitrous in it. Get some decent heads, world makes a great iron head for around $800+ for a set assembled.
              nah for a box i'm convinced that thumper e7's are teh shit
                The only "budget" way I see to do a 351 EFI motor with factory parts is to use an Explorer upper and a Boat/GT40 lower. Use the 302 fuel system and electronics with a HO computer. I don't know that we ever got confirmation of what the hood clearance is with such a setup.
                  Mercracer- I'm hoping to clear the stock hood with a short-runner upper on a 408 stroker. It'll be a long time before I get there, though. IN THEORY, it'll work...
                    no problem with hood clearence i m makin mine a cowl hood i m taking the aleady semi cowl and just extending it up to flowwell with the body lines idk know when but soo and it will be good i laready found a 351 efi with comp for 650 which isnt bad right
                      talk is cheap, man...get to the action!
                      '85 2-Door Crown Victoria
                      302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
                      '04 Crown Victoria LX Sport, '02 Jeep Liberty
                      '83 Suzuki GS 1100E Motorcycle[/color]
                        YES i know talk is cheap action will happen soon b/c my car doesnt like idling right know when its cold out side and theres oil leakin from a good amount of places so its gunna happen i dont know what way to go because this will most lily pass emissions and the sniffer (MFI 351) and the old 70s 302 prbly wouldnt but i could probly get the 70s 302 cheaper
                          Give the kid a break guys... Don't you remember what it was like being young with a bunch of crazy ass ideas in your head, and confusion? Hell, i still got that
                            I got lots of crazy ass ideas too. You find something that will work for your idea the way you would want but then you realize that it is usually way out of your means to get it and cant afford it. I get that all the time.
                              its ok so what it is to make passs emissions and sniffer test in NJ
