oil magically dissappearing??
    I was driving today and the low oil light came on (above the headlight switch) and I added a quart and it went off. Checked the oil and it seemed full though before I added the quart.... She's running perfectly absolutely no smoke out the pipes and no smells and no leaks in the engine compartment or on the ground. Any ideas?
    how many miles since oil change or top off? Burning 1qt/1000 miles isn't noticable.
      mine uses about a quart every 1500 miles
      perfectly normal to use up to a quart every 1000 miles
        its been like 2500 miles since last oil change, so thats not too bad.
          It seemed full before you added the quart because it was probably hot when you checked it...am I right?
          '95 Ford Bronco XL -
          sigpic :rebel:
            Agreed def because it was hot. Both of mine use a quart every 1000-1500.
              yeah it was hot, and my dipstick tube is loose in the block, like I can pull it out so its bent all wierd and its just a mess...lol I didn't know it was normal to use some oil I had a spare quart in my trunk
                heat does not signifiganlty affect the oil level, certainly not by a quart. transmission fluid, yes.
                Originally posted by 89LincolnTWNcar
                Checked the oil and it seemed full though before I added the quart.... . Any ideas?
                dont trust the idiot light!!! ALWAYS check the level before you add oil
                  The dipstick is your best friend, idiot lights, not so much lol
                    Uhh, I have checked my oil when the cars were hot before, yes it makes a big difference. The oil is always way up the dipstick. Esp after just shutting it down. Have to wait for it to get back into the pan.
                    sigpic :rebel:
                      what you are observing is the oil taking a while to dribble back into the pan.
                      The transmission dipstick has hot and cold marks, becuase heat affects its level. the power steering fluid dipstick has hot and cold marks, becuase heat affects its level. the coolant overflow... well you get the point.
                      The oil dipstick does NOT have hot and cold marks becuase..... :p
                        whateva! :p
                        sigpic :rebel:
                          towncars have the low oil light........comes on when it's a quart low
                            Change your oil, put 5 quarts in, and see where it reads on the dipstick. Mine isn't correct, and 5 quarts puts me about 1/2 quart over full. Yours might be off too. This dipsick came from some random station wagon in the junkyard, and has a mark filed into it for full, so apparently it wasn't correct for the previous owner either.
                              I have 2 89 T/Cs. One with only 90k miles on it burns no oil whatsoever. The other, my day to day car, has 227k miles on it and it burns a quart every 1500 miles. It burns more in the summer. I have read about changing the oil every 2k miles in these cars and it does make sense; but, I wait until 3k, after adding 1 quart along the way. I have read that adding oil is not a good idea; thus the change at 2k. This would be economical if you did the change yourself. Otherwise, I have gone a very, very long time with the 3k mile interval and adding the quart. Good luck.
