I can't seem to find a good way to keep the damn oil pressure gauge from leaking!! First I had a mechanical gauge in there and its sender tube burned through and leaked, now I have an electric one with brass fittings to accomodate that huge ass sender, and even with tephlon tape its leaking onto the oil filter. I still have the mechanical gauge, whats the best way to fix this?
my elec oil psi guage is leaking
its not leaking at the block, its around the fitting I used to couple the sender into the tube, didn't use tape I used the liquid gel tephlon.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
I used like 2 turns of teflon tape. Not a drip so far. Just have to be careful about over-tightening it. Pipe threads are on a taper, and it'll split the fittings apart if you wrench them down too hard.86 Lincoln Town Car (Galactica).
