lopo cams
    lopo cams
    anybody know if a cfi lopo cam has similar specs to the efi lopo cam?
    i want to put nates old motor in jeremys old 88 gm for skip and val to drive till they can afford the towncar build
    Run it till the motor blows. :p
    '95 Ford Bronco XL -
    sigpic :rebel:
      Well, pete is doing the exact opposite...
        the only difference I can think of, is the CFI cam is non-roller and the EFI (86 up) cam is hyd roller.
        the CFI cam should physically fit in the block, but you would need different lifters and pushrods to make it work.
          eric i want to run the complete motor out of nates car, heads and all......just want to swap intakes and put on fresh gaskets and run it
            Should be close enough....
            I also have that complete 89 motor sitting in the yard.
              My Chilton manual list some camshaft specs. It says the lopo cam was the same from '82 (as far back as it goes) -'91 (as far forward as it goes) as far as lobe lift goes. It doesn't list duration or anything else that has to do with the actual camshaft profile. It lists lobe lift as .2375 intake/.2474 exhaust.
              For comparison, here are the HO specs for lobe lift:
              '83-'85 HO - .2600 in/.2780 ex
              '86-'91 HO - .2780 in/.2780 ex
                cams are close enough..... just swap the motor in and run it.
