anyone runing an aftermarket intake on the 5.0 MPFI ... holley, trick flow, ford racing ect ... and is it direct fit or what mods did you have to do? thanks
aftermarket intake
That holley was just a lower. No mods needed. I don't think any current members are running anything aftermarket. Most have stock HO intakes or the explorer intake. With the explorer, all I neded to do was redo some of the vacuum lines. The problem you run into is that most of the time you want to put a bigger throttle body on it, which requires a larger EGR spacer, which is nearly impossible to find a bolt in replacement for. To use a mustang EGR spacer, you need to make brackets and/or change all of the cables out.Builder/Owner of Badass Panther Wagons
Originally posted by mrltdThe problem you run into is that most of the time you want to put a bigger throttle body on it, which requires a larger EGR spacer, which is nearly impossible to find a bolt in replacement for. To use a mustang EGR spacer, you need to make brackets and/or change all of the cables out.
Originally posted by beep_beepso your saying that if i change it to the H.O. intake i have to get a larger EGR spacer and change all the cables out? how so?-Matt
With an HO intake, get the stock egr bored. With an aftermaket intake, when you want to run over a 60mm tb, then you run into issues. The only bolt in larger EGR is a 93-95 lightning (65mm), and they are rare as anything to find.
Actually, that's not true, Aussie fords use a vic style EGR and it's 60mm...Only ever seen one over here though on ebay.Builder/Owner of Badass Panther Wagons
