My car does not like to run...It starts up fine but then surges between high idle and low idle until it stalls. It starts right back up again and does the same thing. Even holding my foot on the gas or working the throttle by hand it still idles up then down, almost stalling, then back up again, like a wave at the beach LOL. Eventually it smooths out, still slightly rough, but it stays running.
I tried unplugging the IAC and it just stalls, I cleaned it anyways,it wasn't really dirty though. There is no check engine light. I fixed some vacuum leaks on the passenger wheel well thing and I think I can still hear one coming from under the upper intake. I can't see a vacuum leak causing this problem, could it? I'm gonna change the plugs/wires/cap and rotor/coil this weekend but I doubt they will fix the problem.
The thing is this idle problem got worse after I cleaned the engine, with Castrol Super Clean and water. It used to surge for about 60 secs or so on startup then smooth out. I believe I aggravated the problem
Any ideas?
