Stock lopo specs & times
    Been looking around for the stock lopo specs and times, but most websites no longer have information about boxes. The times I was looking for were bone stock quarter mile times or 0-60 times.
    Associated Panthers:
    boxman ran a 18.56 @ 74.98 in his stock 89 vic with dual exhaust and no cats
      when my car was totally stock, I used a stopwatch to see the 0-60 time and I got 12.2 seconds...if that helps you at all.
        17.76 1/4 for my 87 LX bone stock
        17.35 1/4 for my 91 GM GS, single exhaust, 2.73 rear gears
          129 HP on the chassis dyno. Or was it 119? Let's just say 125...
          '85 2-Door Crown Victoria
          302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
          '04 Crown Victoria LX Sport, '02 Jeep Liberty
          '83 Suzuki GS 1100E Motorcycle[/color]
            NA ran his 91 on the dyno and I think its like 129 ponies. Rated 150 at the crank so 129 at the wheels sounds pretty much on the money given drivetrain losses, etc.
              Yes, and 200+ thousand miles on it...
              '95 Ford Bronco XL -
              sigpic :rebel:
                I ran a mid 17 second quarter mile in my old '89 Town Car with 3.08 gears. I don't remember the actual numbers and can't find my timeslips. I'll dig out my Gtech and take my '90 GM for a ride in the morning. (Just 0-60 numbers, because it's not suppose to be on the road. No new dyno numbers since the dual exhaust).
                '90 Mercury Grand Marquis GS
                5.4L swap coming soon.
