If you had a vac advance, you'd be able to see it sticking out of teh disty. THe adjustment for most advances is inside the housing, normally you'd pull the vac line going to the advance and stick an allen key inside the nipple, usually the adjustment screw is inside there
Symptoms of being a 'tooth off' ????
there is nothing on your 83 distributor, just plug wires and coil wire, no vac advance no pickup assy........83's have a crankshaft sensor instead they are weird
Originally posted by FreshmeatIt's controlled by computer signals, but if the mechanics inside the distributor are worn out, the computer can do what it wants and won't make a bit of difference.
Originally posted by 85crownHPP*hmmm... any one know how to test the electrical advance?? I have a couple spare distributors..
Hey Pete, have you tried running 89 octane in it and see if it knocks and pings the same?
~Adam
'85 2-Door Crown Victoria
302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
'04 Crown Victoria LX Sport, '02 Jeep Liberty
'83 Suzuki GS 1100E Motorcycle[/color]
Originally posted by MercracerThe EEC-IV PIP is fixed in place by the octane rod. .
Octane rod, eh? Just went and looked at the distributor that was originally in my HO motor and it doesn't appear to have a marking on the rod. I see where it is, essentially its a fixed rod that goes where a vacuum advance canister would hook up. I'm idly curious if the 86 lopo and 88 HO engine had a different length rod in there from the factory. Guess I'll have to see if the engineering part number sticker is still on the 86 distributor and compare it. The 88 HO dizzy has an E6 number on it tho so I doubt its different.86 Lincoln Town Car (Galactica).
Originally posted by AODHey Pete, have you tried running 89 octane in it and see if it knocks and pings the same?
Im gonna check the base timing agains wht it is with the shout in. Should I be able to verify the timing advance by watching the timing marks while revving it up in park, or does it have to be actually moving for the timing to advance?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
If you just plug the SPOUT in you'll see it advance with it idling. Should see it swing by revving the motor too.86 Lincoln Town Car (Galactica).
