X-Pipe
    X-Pipe
    I'm putting an X-Pipe on my Grand Marquis today. Anyone else running an X-Pipe on their car? I'm going with an X-Pipe, original Flowmaster 40-Series mufflers (#42443), 2.5" Impala SS tail pipes and Marauder tips. Anyone else with the same combo?
    '90 Mercury Grand Marquis GS
    5.4L swap coming soon.
    I dont think so. I was gonna run the impy tails pipes but they wont clear my tires. But my tires are some of the biggest on the board.
    1989 Grand Marquis LS
      Get us a sound clip when you get done. I've heard that X-pipes cause a slightly higher pitch over a H-Pipe counterpart.
        It's 90% done. I just have to weld on the Marauder tips to complete the job.
          Pics?
          I went standard off-road H-pipe on my '85...
          '85 2-Door Crown Victoria
          302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
          '04 Crown Victoria LX Sport, '02 Jeep Liberty
          '83 Suzuki GS 1100E Motorcycle[/color]
            I'll post some pics soon. My X-Pipe is after the cats. I wanted be emission legal.
              Hows it sound?
              I loved the way my 4bbl conversion sounded with just an open h-pipe :evil:
                I'll be running that once my damn flow tubes show up. Probably won't be using the same tips, and I've got cheapo summit turbo mufflers. If its too loud, I'll stick glasspacks on the end of the tailpipes as a resonator and put a downturn on them .
                  The car sounds GREAT!!! The idle is typical Flowmaster. Nice, deep and throaty, inside and outside the car. From idle up to around the shift into second, it gets louder then evens out. It's difficult to put into words. How do I make a sound clip? Pics will come soon.
                    teh superlinc has motorsport headers, basani x pipe, flowtech mustang flowtubes with extensions, summit polished stainless mufflers, impy ss tails by dynomax, summit glasspacks, and turndown tips
                      my car has all 2.5" exhaust with an x-pipe and impy tails...I've posted clips. With the motor I have it sounds wicked.
                      exhaust clip
                        exhaust clip
                          exhaust clip
                          Are you running mufflers? If you are what kind are they? I love that sound!
                            The mufflers are Edelbrock RPM's...they don't sell them anymore. I had to buy a complete cat back system to get the mufflers. I had the same mufflers on my 87 and it was also incredible.
                              OK, I'm the third guy with an X-Pipe.
