302 Windsor + AOD (1986) - lugging under light load
    Has anyone seen this before? If so where should I start looking.
    CAR
    1986 Lincoln Town Car, 302 Windsor. EFI, AOD
    SYMPTOMS
    The car feels like it missing under light load
    Idle = smooth as silk
    Accelerate = Smooth.
    65 mph = smooth
    35~40 mph: Drive along flat road at a steady 35~40 mph - and accelerate a little (eg up a rise) and she misses a little.
    Have replaced these (with new) so far
    - coil
    - plug leads
    - plugs
    Distributor rotor etc looks fine.
    Rob the Aussie
    Photos
    Founding (and only) member of the CLIPPer Club.
    (Continuous Lincoln ImProvement Program).
    Car: '86 Lincoln Town Car
    Engine: 302 Windsor
    My suggestion, would be to drive in "D" and not "OD" up to about 50-55 mph...
    It sounds like it is lugging in OD...
      +1, maybe adjust the kickdown?
      2000 Grand Marquis LS
      Mercury Owners Group member
        More than likely its the plug wires, at least thats my experience in the past.
        you should also check the ECM for stored trouble codes and check for vacuum leaks.
          I had a similar issue when my throttle position sensor was not calibrated properly. With the engine off and the key on, the (green wire I believe) should measure as close as possible to 1.0 Volt. Mine was set to something like .80 Volts and it would cause a bucking or shudder at the speed you mention.
          I drove the car in "D" only, not "OD" unless I was on the highway. So as mentioned in a previous post, see if the problem goes away by driving the car in "D" only.
          You will not hurt anything by using keeping it out of "OD".
          ~Adam
          '85 2-Door Crown Victoria
          302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
          '04 Crown Victoria LX Sport, '02 Jeep Liberty
          '83 Suzuki GS 1100E Motorcycle[/color]
            Im having the same problem only it happens when its mid throttle, Full or light throttle its fine
            The Terror Of The Streets
            http://www.cardomain.com/ride/2299944
              sounds familiar, i just mash the gas so it downshifts and does about 20mph faster, lol
                That doesn't really fix the problem though .
                  old injectors will do that, and will be smooth in all other ranges of rpm/power and speed.
                    mine are original, kinda figured they were hurtin, lol
                      Bad TPS sensor can also cause that, as can a clogged fuel filter. I'd check the TPS setting and change out the filter to see if that helps. My second guess would be plug wires, but if you've changed them and it didn't help, I guess thats not it.
