OK, but how do you charge the system without the compressor turning? I really know nothing about A/C systems.
Air Conditioning is Functional!
You put some freon in through the charge port, then with the can still connected you fire up the engine and turn the A/C on and let the LPS do its thing - compressor will cycle, at first for very short periods, but as the system fills up the LPS will leave the clutch enged for longer and longer, till tis all full.
Sounds good to me, thanks89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
What he said. It'll start to run as you charge it. As the pressures stabilize towards where they belong, the compressor will quit cutting out.86 Lincoln Town Car (Galactica).
Thanks again, I'll give it a try. If I have a leak in one of the hoses and have to replace it, should I replace the drier too?89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
A friend of mine told me that once a brand-new A/C drier is unsealed, it has to be installed within two minutes or it's bad. I would imagine the same rule applies to an old one .... which in turn makes me wonder why the Ford dealer that last serviced my erstwhile A/C system didn't replace the drier ........2012 Mazda5 Touring | Finally working on the LTD again!
Any time the system is opened up, the drier should be replaced. I'd also do a new orifice tube if you're opening things up. They're 3 bucks and often will be clogged up with crap. The driers sometimes lose their load. The dessicant bag inside breaks and all the sand goes through the system, usually gets caught in the screens on the tube. Install all new O rings on the various connections while its apart too.86 Lincoln Town Car (Galactica).
Like I said I know nothing about A/C. Which one is the orifice tube? Do the O rings come in a kit? You have to use some kind of tool to get the lines apart don't you?89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
the metal disconect tools are the best, but it think i paid around 120 bucks for my two sets
before those were introduced mac had plastic ones...they are like a clamshell....i paid like 60 bucks for that set, they work rather well
the lisle plastic ones are ok for the occasional user......gadgets set is here in the drawer too.....they dont take kindly to wear tho....but at 1/5 the price if you get a couple uses out of em who cares
Originally posted by lincolnmania View Postgadgets set is here in the drawer too.....they dont take kindly to wear tho....but at 1/5 the price if you get a couple uses out of em who cares86 Lincoln Town Car (Galactica).
Originally posted by Glen View PostLike I said I know nothing about A/C. Which one is the orifice tube? Do the O rings come in a kit? You have to use some kind of tool to get the lines apart don't you?86 Lincoln Town Car (Galactica).
