Emission Hoses
    Emission Hoses
    Hi All,
    I plan on replacing all my vacuum, PCV, & emission hoses that connect from the bottom of the upper plenum (1991 GM, 5.0).
    Does anybody know what sizes I will need?
    There's a whole bunch of them connected under the plenum and I'd like to have them before I take my car out of service to do the job.
    Thanks,
    91gmblack
    I put 1/4" ones on mine, think that was the right size.
      there is a bunch of 3/8 and some 5/16 under there.
