what will get me more power
    Step 1
    Make a budget
    Step 2
    Blow away budget by 150%
    Seriously you need to decide a few things up front
    Plug and play junkyard motor??
    Rebuilt?
    Crate motor?
    I will agree that for a stock motor install, a 302 HO will be more HP as it sits than a stock 351 (At least one you will find in some late model truck) Lots of Exploder 302's avail (Best choice) or T-Bird /Mustang
    At least around here I hardly see 5.0 stangs in the yard, though I did see a 85 with the motor still in there, this looked like a CORE all the way, no runner.
    EFI vs Carb
    Boy howdy that is a tough call. The custom swap wire harness is the way everyone does the swaps for a good reason. Sure you can completley re-wire the engine harness/ car harness yourself but that is quite a manly and time consuming project. More of those projects end up never running or are simply a fucking disater compared to the home built EFI conversions that go smooth.
    302 HO's run real nice with a carb, and you can sell off the intake etc...
    2004 Marauder M79 90K miles Jmod!! 14.85 @95.63
    2004 Crown Vic LX 135K Silver Birch Light flint leather FMX1 04 P-71 PCM swap 04 P-71 Airbox and Zip tube "$100 MZT" 01 F-250 70 MM TB 21mm swaybar wood steering wheel BH headlight relay
      Originally posted by Chevyguy
      Step 1
      Make a budget
      Step 2
      :lol:
        Originally posted by 83countrysquire
        will a 351 just plop in and mount with no problwm to the old engine mounts
        You'll need the double sump 351W Oil Pan from a 351W Panther or Fox Mustang Transplant. I don't *think* any other stock oil pans will fit a 351W in a Panther. You could also get an aftermarket oil pan.
          Ford Racing sells the CV pan, new, with everything.
          It is the 351W fox chassis swap pan...
            What they all said. Fox pans and Panther pans are the same.
              Yup, My Canton pan is out of a road race Mustang. Auto Zone sells replacement 351W oil pans for the CV for around $80
