know i want more power but im not shore witch way to go get a new engine like 87 fordmustang engine ho with multifuelport injection and build that up or convert my existing engine to carb in the end guys what eill get me mre power
what will get me more power
K.I.S.S. How much "more power" are you talking about exactly? What are you making right now? Would a rebuilt motor keep you happy? I'm thinking more cubes (351W) and convert to a carb.
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
An HO EFI 5.0L motor makes more power in stock form than a carb 351 stock. Go EFI. A lot of people are afraid of EFI because of the wires, but you get more power, more efficiency, increased daily drivaility, and once you are done installing and setting it up, you won't have to tune it evey month to keep up with the changing climate. If you are specificly going for more power, but don't want to give your waggin up to the track only, then go EFI.
The EFI conversion might not be too bad with a CFI car. It would be best to have an entire parts car, however, for the conversion. It's limited with Speed Density, however, from serious power. A Mass Air Flow conversion would be in order. You might want to look into some of those aftermarket EFI kits. EFI is more of a $ hog to get it running correctly.
My carb runs fine and is a little easier to modify or fix if you know how to tune one. If it starts running rich with a carb, beat on the carb and it's probably fixed. With EFI, hook it up to a computer. Currently, my '95 Ranger (OBD-II) has a check engine light on and not even the Ford Dealership know's what wrong. "At this point, we just start replacing parts."
With a CFI car, you'll have to convert the fuel system to run a carb.1990 Country Squire - weekend cruiser, next project
yeah like i said iwas thinking of 87-91 mustnag 5.0 with multifuel port injectong and beefin it up and thrown it in to my car find a car at a junkyard with ti in it and yank that motor trans and computer with it mainly because stock 275-300ftlb of torquesigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Originally posted by N A"Swap" in a carbed 351 Windsor motor.http://secondhandracing.com/Home.aspx
351 with low compression pistons and twin turbos will get you some power :devil2:1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
