oil psi 50 after warmed up?
    is this possible? my oil pressure gauge i just installed says around 55psi when its cold and 50 - 55 when fully warmed up. Just wondering if maybe the gauge is screwy.
    is the engine/oil pump failrly new? its not impossible - maybe you got a high volume pump.
      I get around the same thing with my TC
        I wouldnt fret, thats great pressure!
          oil pump only has 63,000 miles on it. Maybe thats why.
            That's great oil pressure hot. Does anyone have a service manual handy? I though they called for ~40 psi warm on these cars? But I recall some engines had 50psi hot at idle, so it must be okay. What weight oil are you running? It's probably drawing a small amount of extra horsepower, but I'd always rather have too much oil pressure than not enough. If the gauge was off, I would think it would read higher cold.
            In my dad's '51 Ford, the oil pressure relief valve was sticking and causing oil pressure to build up before we rebuilt it. The gauge went to 100psi, and it would peg going down the road. No ill effects, however, in the years is was driven like that (it was probably driven 5000 miles or so in those last years before the rebuild).
              Better than my 0 at idle in the old car... LOL
                Werd. I was lucky to get the ENGINE light to go off if I nailed it before I started this fucking HO swap.
                  My 91 marq would flicker on the highway, with 20/50 in it. I drove it for 3 months then decided to swap another motor into it.
                  I drove te other car with the autometer gauge that read 0 for a long time. I grenaded the trans first. I haven't actually blown a 302/5.0 yet...
                    I'm on my fourth 302 since I bought my wagon. Sixth that I've had in my cars.
                      my 351 is around 65 or so cold, goes dows to around 30-35 warm at idle. thats with a Melling high volume pump.
                        I think spec is something like 8psi or greater at idle. Anything beyond that is just a bonus. That motor must be really tight. Mine when it was brand new and had no miles on it would idle 30 psi hot. Its now in the 20-25 range where its been since I got to about the 3,000 mile point. My motor is in spec, but barely. Its as loose as permissable by the book.
