FMX BABY!
AOD to C6 swap?
My truck has a c6 in it. I pulled it out cause I broke it and it used to have an AOD. A c6 makes an aod look tiny. I have a pic of the tranny next to my truck.
Its that big
1989 Grand Marquis LS
Originally posted by TiggieI've seen my share of C6's, all of them were good. But for a small block, get the C4 anyday. They used to be somewhat weak (aka wouldn't handle a 390)when they first came out in '64, but they make so many aftermarket parts for the C4 now, it's crazy. I saw them for sale in the Summit Catalog with a lifetime warranty. If I needed a C4, I'd get that one. It was only ~$800.
How about a Ford-a-matic 2-speed from back in the day? You really only need two gears.
Originally posted by DuceAnAHalfThe $800 PA does not have the lifetime warrenty. i have the $1200 PA, you have to get the super-comp C4 for the lifetime warrenty. the super-comp is around $17001990 Country Squire - under restoration
Originally posted by TiggieI thought that $800 sounded like a super deal for a tranny with a lifetime warranty. The $1700 sounds more like it. I wonder if it is one of those useless warranties that doesn't protect against normal wear and tear, as well as abuse? I know the local postman around here goes through a tranny a year because it's all first-second-stop, first-second-stop, etc. He would stand to benifit from that lifetime warranty, even if the transmission did cost more to begin with.
That $1700 tranny is a manual valve body. I would not recomend it to anyone who has to drive a lot.http://secondhandracing.com/Home.aspx
Originally posted by TiggieI thought that $800 sounded like a super deal for a tranny with a lifetime warranty. The $1700 sounds more like it. I wonder if it is one of those useless warranties that doesn't protect against normal wear and tear, as well as abuse? I know the local postman around here goes through a tranny a year because it's all first-second-stop, first-second-stop, etc. He would stand to benifit from that lifetime warranty, even if the transmission did cost more to begin with.Nick
88 Colony Park LS
