know where from i think its the car what could it mean if it is coming from the exhuast
Guys my esxhuast smells like rotten eggs and i got a wierd smoke but i dont
Cataytics are bad, and you should replace the 02 sensors while your at it also.
I have a catted mustang h-pipe that I might be selling if you plan on upgrading to a larger exhaust.Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
Associated Panthers:
Rotten Eggs = Sulfur, which could be coming from the type of gas you use.1990 Country Squire - under restoration
Originally posted by TiggieRotten Eggs = Sulfur, which could be coming from the type of gas you use.
Midas will probably say that the new cats just need broken in or something like that. I've never heard of breaking in new cats, but anything is possible I guess.
Did the reattach the air tubes from the smog system? If they didn't, the reaction occuring in the converters might not be reacting to it's fullest extent due to the lack of oxygen. A sniffer test would tell you if the reaction wasn't going on to it's fullest.
The smell still exists after a long highway run? Try putting some fresh gas in of a good brand name, different from what you normally use.1990 Country Squire - under restoration
