The first of many shipments
    Here's the Federal Mogul c130m coated 3/4 groove main bearings, and the pioneer/powerbond 28oz balancer. The end of this week the coated rod bearings and 28oz flexplate will be here from partsamerica.com :banana:
    '80 Town Coupé
    All that money and you did not buy a SFI balancer or flexplate?
        What year is your TC? Shouldn't that be a 50oz?
          It's going to be mostly a daily driver and will only 6k+ the few times i get to a track. Once i get more into it and start spraying ill put a new flexplate and balancer in when I do a nitrous converter.
          The crank is a 28oz balance setup, so you run a 28oz balancer and flexplate with it. I've got about 10 different applications for the parts I use in this car
          '80 Town Coupé
            awesome!
              Strokers are 28 oz. the majority of the time. with less imbalance it helps with high RPM survivability, less weight spinning around.
                Originally posted by grandpaslincoln
                x100000
                Save a seal, club a liberal.
                  You should use the 50oz balancer as it would make the engine faster like a 5.0 YO
                  2004 Marauder M79 90K miles Jmod!! 14.85 @95.63
                  2004 Crown Vic LX 135K Silver Birch Light flint leather FMX1 04 P-71 PCM swap 04 P-71 Airbox and Zip tube "$100 MZT" 01 F-250 70 MM TB 21mm swaybar wood steering wheel BH headlight relay
                    Oh- wasn't paying attention to the stroker bit. I get it, now.
