this is a BITCH
    this is a BITCH
    I am putting on these Flowtech headers and let me tell ya it ain't easy!! The H-pipe and the header don't quite match so I have to push the whole assembly around to get even one bolt in, which is On top of that I pulled my dipstick tube out of my block, which is really
    Ive found thats a problem with the damned flowtech headers. i had the same problem...
    I filed out the elongated holes for one of the h-pipe header flanges, and it finally worked...
      Just be glad you didnt buy used MAC headers :dance:
      '80 Town Coupé
        Yeah, no shit!!
        Those are a royal cocksucker!
          Oh, so now that GMGTs in England, he feels he has the right to say, "Royal".
          89Linc- be glad you don't need to change your exhaust flanges that meet up to the headers entirely. Something's not lining up right on mine, so I need to have new flanges installed.
            I've always used the term "royal cocksucker"...
            It just sounds better here
              Tom, just don't use the time-out hand gestures. In England, that means up-yours.
              Save a seal, club a liberal.
                got them on finally, sounds better but I don't know what it did for the power. then again I won't know till I fix my injector problem
