So far this week I replaced the TV grommet with a brass one, and today I drained the pan and replaced the fluid. I did not have the chance to drain the torque converter because of weather problems. I was basically covered in mud and tranny fluid all day. I added some Lucas Tranny additive to the new fluid I put in. The other day when I replaced the grommet, I adjusted the TV pressure. When I drove it though, I noticed no difference. Is it possible I fucked up the TV adjustment. I disconnected the TV line from the throttle body, then I took a cinder block and placed it on the gas pedal so that I could work freely with both hands. I popped the white tab out, made sure the rod moved freely, and then set it to max.
Right now, the car shifts under moderate throttle at about 19-21mph. Then as you accelerate to about 30-32, it kind of feels like it's bogging down. I have been driving it in D, not OD. Any ideas?
