Not fitting.. Why?
560k6 Belt (ASAP)
560k6 Belt (ASAP)
1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
SupermotorsTags: None
Sounds like you should have ordered a short bus, not a short belt.
its REALLY tight, in fact I didn't feel like putting it back on. You have to move your tensioner all the way to the bottom of the slider to even think about getting it on.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Alright. Thanks for the tip.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
Hmm. I actually wasn't really that bad if you pull the small pully head off.. Losen the tention all the way. Put the head back on, and than push down on the whole thing, tightening the bolt in the back. Worked good.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
I put mine on with a tire tool. It was a bitch.Project \"Fire and Ice\":
1989 LTC
My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
Anton Szandor LaVey
I actually had no trouble once I took the smaller pully head off. It went right on.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
