Ummmm.. What the hell does the air pump do exactly? If it's fucked.. is it considered a vaccume leak? That's going to fuck the perfomance of the engine? Is it even a vaccum line, or does it just pump air to the cats..... which I don't have?
Air Pump
Air Pump
1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
SupermotorsTags: None
Pumps air to the cats and the back of the heads. There is a vacuum hose to it from over near the cruise, its a 5/16 line. Pull and cap it. The two small lines go to the control solenoids. Cap those too. Pull the pump and toss it in the scrap pile. If you feel like getting out your skinny hands, you can remove the air manifold thingy from the back of the heads. If not, get a 3/4" rubber pipe cap and clamp it over the end of the air manifold. Install a 560k6 belt and be happy.86 Lincoln Town Car (Galactica).
Man. What am I going to do in janaury. No cats, no air pump.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
Wouldn't you want the air going to the back of the heads though?1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
the air holes in the head are just emissions related, if anything they pump extra air into the exhaust ports, thereby reducing how much air can flow out of the cylinder. remove the air pump parts and plug the hole in the heads with a 5/8-11 x 1" bolt.http://secondhandracing.com/Home.aspx
If you have cats, and you go through smog testing, it should be fine. The smog pump vents to atmosphere once the engine is warmed up anyway. The lack of cats is whats gonna fail you, not the smog pump. Unless you live somewhere thats both really anal and does visual smog inspections as well as emissions checks.86 Lincoln Town Car (Galactica).
Well my dad can get me past so i can rip it all out.1989 LTD Crown Victoria LX.
4 Door Muscle
Supermotors
