Well....F&*%^$
    Well....F&*%^$
    Oh, well..
    Pulled the upper intake to do the rockers...lots of oil in the runners. Oil in the MAP sensor. Tried out the rockers. Not enough adjustment to compensate for the cam. That was a waste of 370 bucks...So I still need new pushrods. At this point I might just put the stock cam back in and say fuck it. All I can do right now is drive it. No place to work on it, not much time either.
    Damn, that sux. I popped my pass valve cover off of the towny to see if I could locate the source of my ticking noise. No dice, I think it is slack in the timing chain, but I cant really adjust that. Now Im just waiting until I have money to replace my engine, just hope it holds together in the mean time.
      mrltd- what problem are you having, exactly?
        :cuss:
          I think his pushrods are too short for the cam he's running IIRC.
          Nick
          88 Colony Park LS
