Headlight switch
    Headlight switch
    Does anybody know if the connecter is the same with or without autolamp I need to replace mine and there is a big differnce in price. thanks
    I don't think there is. I took a light swtich out of a town car. Totaly diffenret autolamp system. Hooked right in minus the autolamp.
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
      Im pretty sure they are different...
        Thanks Ill just have to look atboth at the parts store.
          Ken,
          I had the same problem with a 89 Marquis. Go to the parts store and but a switch for an 88 F-150. Same connector, minus the autolamp. Only hitch is that the knob shaft is longer for the original autolamp switch. What I did with mine was I put the original shatft in, removed the knob, and bent the shaft at a right angle so it was "L-shaped". Worked perfect after that, and saved about $60.
