Brake Booster
    Brake Booster
    Alright. Going to buy a brake booster this weekend. My Saturday is completly free so I have nothing to do. I figured I'd install it myself. Yes I know, me.. I know.
    Anyone have a good set of instructions they'd like to share or a website with step by step instructions?
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    Get a booster for a 1992+ Panther. It's smaller in diameter and will clear clutch cable, should you ever opt to go manual.
    There are two bolts holding the brake reservoir to the booster and four bolts holding the booster to the pedal assembly inside the cab.
    Make sure you remove the clip attaching the booster shaft to the brake pedal.
    It's easy.
      Eh I'm not going to go manual.
      Smaller booster is better? Why? Because it's does the same exact thing and just takes up less space? (Simple as that?)
      It bolts right on no mods?
      4 Door Muscle
      Supermotors
        Bolts right on, no mods.
        It's a decent bit thicker, but still a lot smaller.
        Six bolts and the pin on the pedal.
          Don't forget about the vaccum hose.
            Yes, it's just that easy!
            Walk softly and carry a BIG SIX! ('83 Bronco w/'95 EEC-IV EFI 4.9L conversion)
            My '94 CV w/2000 engine/trans & '99 P71 EEC (OBD-II conversion)
            A '75 Bronco I built for a friend ('88 EEC-IV EFI 5.0L conversion)
              Well I'm saying why get a smaller one? Just to save space?
              OR is that what you ment steve?
              4 Door Muscle
              Supermotors
                Smaller space and clean it up is all. No performance difference, I don't think.
                If it bothers you that much, just stick with the original design.
                  No I just wanted to know if that was the only reason.
                  4 Door Muscle
                  Supermotors
                    Get a good quality replacement. Seems the reman ones are problematic and tend to leak. They kinda suck to replace too, so you aren't gonna want to change it a bunch of times just to get a good one. You'll also want to make sure your master cyl isn't leaking. Probably just a good idea to replace it with the booster, as lots of times you get no warranty on the booster if the MC isnt changed.
                      I don't think it's leaking. The fluid never goes down.
                      4 Door Muscle
                      Supermotors
                        That may be, but you will probably void your warranty on the booster if you don't replace the master cylinder.
                        Save a seal, club a liberal.
                          Well I could always go ahead and replace it after if it fucks up, lol.
                          4 Door Muscle
                          Supermotors
                            Just save yourself the aggravation and replace the master cylinder when you do the booster.
                              That's like another 80 bux though. I have to do an oil change... and I'm not going to work tomorrow.
                              4 Door Muscle
                              Supermotors
